tune up on b16b engine
Old 09-07-2017, 05:08 PM
Mr. B16's Avatar
Default tune up on b16b engine
Quick question, could I use the same tune up kit, (timing belt, water pump, spark plugs, fuel filters, etc.) for a usdm b18c5 itr for the b16b engine?
Thanks for the help.
Old 09-07-2017, 06:08 PM
White_EG1's Avatar
Default Re: tune up on b16b engine
I'm not sure how many teeth the CTR or ITR belt share so hopefully someone who knows could chime in. But everything else should be fine. Or I'm sure a quick part search seeing if the numbers are identical would work.
Old 09-07-2017, 09:38 PM
JRCivic1's Avatar
Yes, you can use ALL tune up parts from a B18C5 for your B16B engine. Timing belt, water pump, distributor cap, rotor button, spark plug wires, spark plugs.
Old 09-08-2017, 05:28 AM
mk378's Avatar
Fuel filter type would be what fits the original car. Swapping the engine doesn't change that.
Old 09-08-2017, 05:38 AM
Mr. B16's Avatar
Nice. Thanks for the help!
Old 09-08-2017, 11:46 PM
egsleepercivic's Avatar
b16b is a destroked b18c, timing belt is the same as type r and gsr
mrinno
09-19-2007 04:55 PM
Fat Chick Magnet
01-31-2007 05:47 AM
1990crxsir
06-02-2006 12:55 PM
jizzer671
06-02-2005 12:40 AM
alleyezonme
04-08-2004 08:26 PM
Quick Reply: tune up on b16b engine
