I need of help urgently
Hey guys
Need help just wana know whats wrong with my honda civic 1.6 1996. 200000 mileage. Raced a other driver then when i chnged gears car broke donw and had a different sound like an old really old car oil spillage at the back of exhaust and when i start the car still hve that old car noise and than die it cant idl.???
Re: I need of help urgently
First off only d!cks street race. Your putting yourself and other people at risk for 10 seconds of blowing your load.
Does your engine make noise now.. as in rod knck or spun bearing? Is it manual transmission (gear) oil or motor oil you are seeing? Is it an automatic or manual transmission?
Sounds like and old car is not a description.. be more specfic or better yet post a video of the noise.
It is an old car.
It is likely that something inside the engine broke. Do a compression test. If compression is good, or at least no cylinders are zero compression, check if the timing belt skipped.
Yea man I agree with Megalodong.. these are the consequences when you try to race with an Economical car. Your issue is very wide you need to narrow it down it can be as simple as the timing belt skipping to doing some serious damage inside, to me it sounds like your definitely going to spend and learn a lesson. GOOD LUCK!
killerB16A
27
07-11-2006 12:11 AM
