Clutch release bearing
ok guys. I need to replace the clutch release bearing from my 98 DX. My question is, majestic honda has 2 different brands for this part. does it really matter? NSK or FUJIKOSHI? how hard is it to drop the transmission on these cars, should it take me a couple hours only? Thanks
Re: Clutch release bearing
Dont think it matter. Match up the vin and u'll be fine. Couple hours? If its your first tranny drop, expect a full day. Since you want to go slow and take your time. Better have a friend or two there to help. You will need it.
have the FSM handy, you will need it.
once the tranny is drop, the bearing takes less then 10mins to swap out.
hardest part, putting the tranny back in and line it up..
if you are dropping the tranny, may as well do the clutch, resurface flywheel. If the rear main seal is leaking, its time to do that too.
crvtt717
10
10-07-2007 09:05 AM
ShAqFu
04-30-2005 09:45 AM
