How do I replace the following and what part(s), do I need?
Hello all,
Turn signals:
My turn signals (both L & R) stay on, after turns are completed and I have to turn them off manually.
What part(s) do I need?
How do I replace?
Horn: Buttons.
Do I need the full buttons i.e. (78521-S01-A82ZB & 78522-S01-A82ZB) or is there a cap?
How do I replace?
Air Filter: Housing clip
Can I replace just the AIR CLEANER CLIP #17217-P2J-300 or do I need the AIR CLEANER CASE #17240-P2J-000?
How do I replace?
Turn signals:
How do I replace?
Horn: Buttons.
How do I replace?
How do I replace?
Re: How do I replace the following and what part(s), do I need?
There is a part in between the clock spring and the turn signal switch that cancels the turn signal after you complete the turn.
The clips detach from the lower air filter box and can be replaced separately.
A factory service manual will answer these questions. You need to read the factory service manual to know how to safely remove the air bag. That is necessary to fix the horn buttons and turn signal.
Corvette Forum Member
Do yourself a favor and order a Helm manual for your car. I did, and it was the best choice I've made regarding this car. Loads of good info in there. helminc.com
I'll do some further research, to narrow down the part in between the clock spring and the turn signal switch
I have the factory service manual but unless, I missed it; it wasn't very helpful with how to replace the clips from the lower air filter box, so I appreciate the feedback.
That said, I'll check the factory service manual, to see how to safely remove the air bag, to fix the horn buttons and turn signal.
As for turn signal, I believe this thread shares the part I need, along with at least one user's install instructions.
Part #35251-S04-A81 "BODY, SWITCH" (36MM); $11.08 @ Majestic (see illustration #7)
When it comes to taking the steering wheel apart or anything with SRS in case you forget to read a warning about it. Always disconnect the battery and wait at least 30 minutes sometimes more is recommended by the manufacture to allow the current to dissipate in the capacitors. I take off both cables and put them together if possible.
JimmyM86
Honda Civic (2001 - 2005)
05-16-2008 08:39 PM
misterghost
Honda Civic (2006 - 2015)
03-18-2008 07:41 PM
Run Hatch
09-07-2004 11:28 AM
