Do i have a P28?
Do i have a P28?
I just bought a ecu from someone with a hondata unit. The ecu i bought the guy said came from a stock 93 si. The bar code was scratched off in the middle. The only numbers i have are 37820- then rest is scratched off. The bottom line says 740-512 and has in big letters APX. Is there any way to look inside ecu to see diagram to see if this is a manual P28?
thanks...
thanks...
Re: Do i have a P28?
no. Im sorry i thought i had said that. I bought the hondata s200 unit off someone. and he sold the ecu with it. said was from a 93 civic si. I just wanted to make sure.. i will check the inside thanks..
ok thanks i found the other barcode the first line says 37820-P06-A00 the second line says 740-512933 3A06 .. Does this mean i have a P06? How can i tell if its manual or not? I was reading you can make the P06 a P28? Anyone help with that? thanks.
The guy scratched off the number because he is a D-bag and he was trying to hide the fact that it’s not a "real" P28, but it doesn’t matter. If it really has Hondata then it is most likely already manual and converted to VTEC, which is now just about identical to a P28.
k ill get pics up tomorrow. If i get the ecu chipped when i get my car tuned can they put in the chip so that vtec will work? Or would i have to convert the ecu still?
