TDC Sensor 8
TDC Sensor 8
Car is running .. idles very low but it starts and runs i'm throw code for TDC (top dead center) #8 what should I do? to resolve this issue?
Re: TDC Sensor 8
pull your positive battery post off . . tap your breaks wait 15 minutes and see if it goes away . . if it doesnt then you know something is wrong .
Re: TDC Sensor 8
i've been driving it a little it seems to bog a little low in the rmps i dont know if the ignition timing is off a bit or what
Re: TDC Sensor 8
It is possible that there is just a wire that is loose. Go to the shop manual at http://ww1.honda.co.uk/car/owner/workshop.html and see the tests for the sensor there.
I expect your gas mileage will improve with a new dizzy housing. IMO those three sensors do degrade with time. I recommend replacing the housing every 150k miles/10 years.
