help 97 ex shell,00 ex motor questions
okay so i bought a 97 ex coupe shell and i bought a 00 d16y8 motor
i got a 00 stock ecu and i got a 00 engine harness
i took it to a shop and they said i need a 97 ecu and a 97 engine harness
is this true at all
is this true at all
Re: help 97 ex shell,00 ex motor questions
96 - 98 OBD2a
99 - 00 OBD2B is the only difference. ( U may need to get a OBD2b to OBD2A harness for the inside where the ecu is connected. ) do engine harnesses have that part i forgot?
Seagull Management
Originally Posted by Ser1N
No, if its a 00 engine using a 00 ecu and 00 engine harness it will work fine.
96 - 98 OBD2a
96 - 98 OBD2a
so if i just bought the adapter id be able to run with no problems?
or would i still have to buy a new distributor ?
Seagull Management
you'll still need to buy everything I listed above, the only thing it gets you out of buying is a '96 - '98 EX ECU which I forgot to mention in my previous post, you can probably buy an '96 - '98 ECU for less than you can get an adapter harness for anyway. You should also be able to sell that '99 - '00 EX harness btw, EX/Si engine harnesses are always hot items.
i got a 98 harness sitting in my garage i bought that one 1st then someone told me i needed to get a 00 harness and i bought the harness adapter for 100 bucks shipped im gonna go out and get the distributor sometime soon
but thanks for the info i couldent figure it out to save my life
thanks man
thanks man
97booger
07-05-2009 04:52 PM
DeucesWild
04-02-2008 12:01 PM
