EG Inner Fender Lining
One of my inner fender lining got torn up so I am just going to order two new ones from Majestic Honda but I wanted to know which clips I needed.
http://www.hondaautomotiveparts.com/...5=FRONT+FENDER
I know I can reuse the screws that were used to hold mine on, but it says I need 16 clips which are illustration no. 014. And what is the stay which is illustration no. 002 and 004 for both sides. I am not sure if I will need the stay and the other bolts that hold that on, or what.
can anyone help me out?
Re: EG Inner Fender Lining
If you take your time all the clips can be reused. use a lage philips head screwdriver to turn the platic screw out about 1/4 inch or so then pull the clip and screw out when you put them back in just push the plastic screw in with your finger
Well since my lining got really ripped up before I took it off, I don't know how many clips got torn off and how many are still there. I remember unscrewing the 3 phillips screws and that was all I needed to do to take the lining off. Does the stay thing belong with the fender lining or is it something else for the fender itself?
when my fender lining got mess up, and i had to replace it, i took one of the clips to the auto store, and they just gave me a box of the same size clips for about $7 to $10 depending on what size they are. just do that instead of paying for shipping.
Ok, that sounds like a good idea. But my main question is: Do I need to order the stay?! It looks pretty big and its numbered illustration no. 2 and 4 (driver and passenger).
No you should be alright without replacing it. It should be made of metal and if its bent a little you sould be able to bend it back
trevorjohn88ef
03-30-2008 10:10 PM
DBLAZE
04-30-2005 10:48 AM
