Help...my car will not start...but I know it is fuel related.
So i just rebuilt my motor( d15b7) and its started and ran pretty damn good. The same night i put my axles, shift linkage in, and finally did a last minute compression test. Number were great but after that my car has not started again. I used starting fluid and it started right up and ran as long as i kept spraying liquid out the can. It immediately dies after spraying. I know its a fuel problem. I have pressure at the fuel rail so im pretty positive it is not the pump. I then did i voltage check at my injector connectors. 3 of the connector tested one side 12v and the other 0, which means one power wire and one ground. However my 4th injector connector had 2 positive 12v readings...how is this possible? im lead to believe this is why my car is not starting but...i cant figure out what would cause this problem. I have replaced the ecu and that didnt change anything. Please help!!! I need to get back on the road asap...let me kno if you guys need more info...
Re: Help...my car will not start...but I know it is fuel related.
Anyone have any idea? Im thinking to make a wire for the #4 injector that comes directly from the ecu...would this work?
By the way, my impression is that engine should start but run poorly with one bad cylinder.
I'll go ahead and do those checks. I think ur right to about the running poorly thing...but um also thinking that all the fuel is just pushing through that one injector. I swapped the ecu but it gave the same reading...I hate wiring issues
I checked my harness and behold there was some incorrect wires going to the wrong place. After i fixed the wiring it started right up. Only problem is since i had 2 positive wires at the #4 injector the resistor inside the injector was burnt out. So after replacing that injector i should be hitting the road again. Thanks for the input...
chairbot
11-22-2012 05:46 PM
