auto to manual help!!!!!
i just did a auto to manual conversion...i got everything done...i just need to know if i need a obd2b ecu with a 99 harness....my car is a 99 civic and the motor is a 97 and it has the stock engine harness...so i was wondering if i need to change that out so it will start...because i have 4 plugs that plug into the ecu and the 97 ecu i have olny has 3 plugs...is there something im missing.....
Re: auto to manual help!!!!!
it has 4 plugs because it was auto. One of them went to run the auto tranny. Unplug it as u dont need it anymore and do the IACV fix.
Seagull Management
If its a '99 - '00 chassis you need a '99 - '00 engine harness. If its a '96 - '98 civic you need a '96 - '98 engine harness. If you try to run a '96 - '98 harness in a '99 - '00 civic or vice versa you will find that the engine harness does not plug into the underdash harness. As already stated the reason your harness has an extra plug is because its an automatic harness. I do recall Katman saying he had weird problems with not being able to get vehicles to start with automatic EX harnesses and could never figure out why, not sure if this also applies to Y7 harnesses, just kind of a heads up in case the car doesn't start.
Nismo13s
20
10-18-2016 04:51 PM
Mario Garbey
05-11-2012 07:54 AM
webafile
10
01-17-2012 03:45 AM
devonic
09-12-2003 04:48 AM
