cluster problems
cluster problems
i just finished my swap in my car and my cluster isnt working well the tempature gauge and gas gauge are but my odomoter,speedometer or R.P.M isnt working its a si cluster in a 96-98
Re: cluster problems
there is a solid blue wire on your distributor plug packdo a volt check on that while the car is one. repport back with your findings
i swapped out the cluster during the swap but the si cluster worked fine in my other car idk what it is im using a 99 si engine harness someone told me i might have to use the orginal harness out of the 96-98 civic bump
swap out the cluster to a car w/ a good known harness to see again if it works. if it does u have a wiring issue
most of them are plug and play keep messin around with them until you got then on right u might have gotten a defective cluster just may not work period man
yea but my cluster worked fine in my other car so i dont think its the cluster does anyone have a b-series motor in a 96-98 anf if so do you use the 96-98 harness or something different
