Brake Booster!?!?!?!
Okay so this is kind of a wierd question. I have a 93 Del Sol SI with a d16 in it. My brakes are messed up and we thought that it was the Master Cylinder. Well we replaced that and it's still doing the same thing, So the next plan of action would be trying to replace the Brake Booster. Now heres my question i have a 95 Del Sol V as a more less of a parts car. If i was to take off the Brake Booster and Master Cylinder could i use them on my 93 Del Sol? I know that we tried using just the Master Cylinder and it would not work because the studs on the Brake Booster were in diff spots. Has anyone ever tried this? And will this work? And if it does are there any Pos/Neg side affects to this? I would just go out and buy a new Brake Booster but there like 175 from autozone and this just seems easier. Thanks in advance!
Re: Brake Booster!?!?!?!
Off hand I dont remember if the del sol is ABS or Non ABS but as long as the donor car and the recipient car both have ABS or Non ABS setups your good to go. I do recommend taking the BB/MC of your salvage car and put it on your sol. I had a similar problem and it was my MC. I had to let my system do a gravity bleed to start getting pressure to all four wheels...
fourbeam
01-19-2017 12:01 AM
GrabAWiski
07-08-2011 08:34 PM
