Lug nut just spins
Old 01-10-2009, 06:38 PM
standbackimapro's Avatar
Default Lug nut just spins
well i was taking off my wheels, when i got to the rear one, one of the lug nuts just spin, and i think the stud is to, how can i get it off?
Old 01-10-2009, 06:56 PM
blueg6's Avatar
Default Re: Lug nut just spins
i dont think you gonna get it off unless you snap it off.. this happened to me but in the front. ended up snapping like 2 off of each wheel then replaced them with arp studs. your gonna need a BIG hammer. goodluck.
Old 01-10-2009, 08:07 PM
The_Honda_Guy's Avatar
Most likely if it's spinning you're going to need to drill it out or try to grind it off. Most likely you're also going to need a new rear hub/bearing assembly.
Old 01-10-2009, 08:18 PM
jesus, someone else suggested grabbing the rear of the stud with vise grips and holding it,but i dont think i cant fit them back there
Old 01-10-2009, 08:29 PM
I'm sure if the lug nut is so tight that it's spinning the stud you aren't going to be able to hang onto it with a vice grips. If you try to do it that way I'd hope you have an impact gun to go along with it.
triumph_013
02-05-2013 11:25 AM
tallblondkid
06-05-2011 08:54 AM
headrec*
05-06-2008 12:45 PM
gsrteg97
Suspension & Brakes
02-21-2005 04:12 AM
magic hat #9
08-07-2002 07:30 PM
Quick Reply: Lug nut just spins
