IACV and idling problem
1998 civic stock d16y7, car was throwing an IACV code but was still running (poorly). I replaced the IACV and the code went away but now the car will not start, it cranks and tries to start about 3 times then just keeps cranking. I pulled the plugs and theyre covered in gas so the car is getting fuel which leads to no spark, but I checked the spark and its sparking. My only thought is the car is not getting enough spark the real kicker is that there is no CEL which makes this even more difficult. Any help is appreciated...thanks
Re: IACV and idling problem
Have you tried starting it with the throttle partially open? What about the fuel pressure regulator? Does it have gas in the vacuum hose? If it does, the diaphragm is leaking and not regulating pressure. What does the timing look like? Did you get a nice blue/white spark when checking? Check grounds, like namewasdallas suggested. Make sure they're all clean.
There are no codes at all and I tried starting with the throttle wide open and it tries to start a few times then just keeps cranking over. Ill try all the suggested tomorrow in the day light...thanks for the help keep the ideas coming
hawjboi
17
11-11-2008 08:56 AM
rewerbcrx
24
03-11-2006 06:40 AM
