95 CX 2dr D15B7 P06, pre-wired for Vtec??
I've looked EVERYWHERE and all I could find is people talkin about 92's and Preludes etc.. So I'm sorry if this has been answered but I'd really like to kno. And I have another question, the mini-me's.. Can you do a B18B1 block with a vtec head? All I seem to b able to find is people doing the vtec heads on SOHC's. Any help would b appreciated guys.
Re: 95 CX 2dr D15B7 P06, pre-wired for Vtec??
I'm pretty sure the CX isn't wired for VTEC and the O2 is wrong for the d15b7 you have in there if all the wiring was left alone. They make conversions so you can wire up vtec with the existing wiring harness and the same goes for the O2, since the CX uses a 1wire O2 and other motors require a 4wire. I believe www.rywire.com sells the conversion harnesses and I'm sure Ebay has them as well.
92s were prewired to the cannon plug on the driver's side. You can convert your ECU to 4 wire O2, add VTEC and chip it if you want to save a little money.
Cool guys ty. That's wat I needed to kno, Any other info on the other question? Can you do a B18B1 block with a vtec head?
Ls/Vtec conversion? like Civicspoon said theres more to it than just slappin a Vtec head..you gotta tap the head for your oil lines and wat not..
Sweet! You guys r FN awesome :-) will do, I jus got a sweet deal on a full B18B1 swap hellllll ya ;-)
its a pretty reliable conversion if you do it corectly search how to build a reliable ls/vtec on this site.This is pretty accurate and good detailed information so you will know what you are getting into good luck.
