Code 6 - D15B2 in 92 Civic DX
Stock motor died so I put in a D15B2 from a 90 Civic and swapped intake manifolds to convert it to OBD1. Everything is plugged in. When I turn the key, the temperature needle immediately shoots to the highest point and I'm throwing Code 6. The car runs but it smells and feels rich. It probably doesn't help I'm running a PR4 ecu but it is all I have at the moment. Anybody know what could cause this code?
Re: Code 6 - D15B2 in 92 Civic DX
go on to www.wikipedia.org then type in honda d engine then look for your motor it will tell you everything like what ecu to run..you can also try to run a p08 that might also work thats what im running in my d15b vtec
