single cam dumpin fuel and wont start
hey wa swup please help i have a 96 hatch single cam and wont start. i have spark its gettin fuel. compr. is as follows.. cyl 1-120 cyl2-115 cyl3-35 cyl4-85. it was runnin last thursday but i ran out of gas so friday i put gas in it on friday morning and it has started since. please help i kno sumone can help me please...
Re: single cam dumpin fuel and wont start
35 and 85? that motor is gone. Either your valve seals are gone or your rings are gone.
and what do you mean by dumpin fuel?
The low compression of cyls 3 and 4 also could be the result of flooded cylinders caused by stuck open fuel injectors. If flooding is not the problem, then do a cylinder leakdown test.
Cylinder compression depends in part on a thin layer of engine oil coating the cylinder walls. Fuel flooding of a cylinder dissolves this import oil coating, thereby diminishing cylinder compression. That's why flooding can result in a no-start problem.
makes sense. thanks
did you do the compression test with the engine warmed up and wot? cause if you do it cold. it is pointless because the metals did not expand
Hersheybar06
08-03-2013 06:13 PM
bri1998
01-08-2008 09:18 PM
