NEED HELP HIGH VOLTAGE PLUS 3 OTHER CODES
I BOUGHT A 96 CIVIC CX AND IT NEEDED A WIRING HARNESS SOMEONE HAD HACKED IT UP SO I GOT A WIRING HARNESS FROM A 97 DX AND PUT IT ON AND IT FIXED ALL THE PROBLEMS I HAD BUT KNOW I HAVE A NEW PROBLEM IT HAS 4 CODES COMING UP KNOW
1. ELD HIGH VOLTAGE
2. TPS HIGH INPUT
3. COOLANT TEMP SENSOR HIGH INPUT
4. INTAKE AIR TEMP SENSOR HIGH INPUT
I HAVE PUT A DIFFERENT FUSE BOX IN THINKING IT WAS THE ELD DIDNT FIX ANYTHING AND I HAVE CHECKED ALL THE FUSES AND GROUNDS AND THEY ARE ALL GOOD NEED HELP IF ANYONE HAS ANY SUGGESTIONS
1. ELD HIGH VOLTAGE
2. TPS HIGH INPUT
Re: NEED HELP HIGH VOLTAGE PLUS 3 OTHER CODES
Probably problems that ur old harness was not detecting thanks to the last idiot who messed with the old harness. Does the car runs smoother with the new harness?
I COULDNT ASK FOR THE CAR TO RUN ANY BETTER BUT I WANT IT FIXED ALSO I FORGOT TO ADD THAT WHEN I TURN THE LIGHTS ON AND HIT THE BRAKES THE ENGINE SURGES UP A LITTLE BIT
