cant read cel on jdm eg6 cluster
Rotary Lift Specialist
hey all, i finally got my car running again after a fire, got the interior harness and engine harness tucked, i chipped the ecu myself, ran new battery wires and whatnot, but i notice the car is running a little rough and the check engine light is on, so i jump the little plug and turn the key to the on position and the light just stays on solid and doesnt blink, i am just wondering if this is due to me having a jdm cluster in my car, any input is appreciated
Re: cant read cel on jdm eg6 cluster
it should still work. my bro's hatch has a JDM cluster with a K swap and the check engine light still blinks and works if there is a code popping up.
it might have to be something with your wiring maybe? did you have to cut and splice wires?
as for the wiring i had NHswaps13203 did it, he is very good at what he does, the car starts and idles normal, at first i had to change the map sensor plug, which nick explained i might have to do, only when i hit the throttle does it sputter which i believe is the O2
ill try swapping it out with the other chip i have, i got the kit from xenocron so ill call them if the problem persists, for some reason when my engine harness was made there was no oil pressure switch for vtec on it, so that will also be looked at, but i dont know if thats what could also be causing the cel
pretty sure, i got a paperclip in the little blue plug on the passenger side of the car, im gonna try putting the old chip in the car and see what happens right now, worst case scenario i gotta get a new ecu, oh well
http://wikitest.pgmfi.org/twiki/bin/...roubleshooting
this is great guide for u
tell u what u could do. take out your eeprom and start the car. if it doesnt run worse then u know u have a connection problem somewhere or just bad ecu. if it does then u must just have a bad map
yeah ill try that tomorrow, i plugged a different ecu in and was actually able to flash codes, started up fine, it either flashed a 7 or a 16, 7 is TPS sensor, which is plugged in and 16 is injectors, this thing is gonna be the end of me
Not meaning to thread jack, BUT; To the people that have a JDM cluster in the USDM car, how do you get the OEM dimmer switch to operate it? The US has the yellow and the white clips, with 5 pins each. And the JDM has an opening for a single green clip with four pins. I checked the sticky, but I cant find what I am looking for.
Beckerton
48
06-25-2011 04:09 AM
b20accord
05-16-2007 10:46 PM
crew08 (girlygirlracer)
23
03-24-2005 02:54 AM
