Ek engine wiring Help (motor change) auto to manual
I am working on my brother 96 ek. We did the whole engine change from auto to manual. I am having issues starting it up. It seem like there is no power going to the fuel pump. I changed the fuel pump and it wasn't it. SO I thought it was the main relay. So I changed that too. Still no fire. So I was looking at the engine wire and there seems to be a wire that is not plug in. It is on the driver side, it have only two wire (blue and green). Does anyone know where this wire might be hook up too? I looked everywhere. I will try to get pic up...I also changed the ecu and dizzy too.. it just wont fire...dy16z
Re: Ek engine wiring Help (motor change) auto to manual
On the 14pin connecter on the auto harness, did you connect the 2 larger gage wires together? If not, it will tell the ECU not to give power.
Butt connect them, and try your luck again
kyliejohn1129
04-30-2012 09:59 PM
