95 SI BRAKE CHANGING PROBLEM!!HELP
trying to change the brake pads but when everythings off and im trying to C-clamp the brake moduler back in to put the new brakes in it doesnt go...i turned the e-brake off after i took the two bolts off the calipers...never had this problem was it that i took the ebrake off after that made it lock up and not let me push the moduler back in???let me know honda-tech guys...
Re: 95 SI BRAKE CHANGING PROBLEM!!HELP
cap was off though...wat do you mean they screw in? sorri never changed one on a civic this is my first civic haha...wat tool would i use so i dont need the C-clamp?...thanks bro
When you compress them you need to spin them, like the bottle caps on pill bottle lol. I have always been lucky and been able to do it with pliers.
or there is a cheap little cube tool with different tabs that fits on the end of a rachet, or you can use pliers as stated above, there will be grooves in an X pattern on the piston on the rears
bpetruzzo
09-01-2004 02:55 PM
