obd1 jdm15bV wiring help
hay guys i looked around i am needing a wiring diagram, the one with colors of wires for a jdm d15bV, i know ppl will say oh it wont work in a usdm car that is fine i am taking parts of one harnss(usdm) and using the main parts of my jdm d15bV harness to make a usdm harness for a tuck
thanks in advanced
thanks in advanced
Seagull Management
Re: obd1 jdm15bV wiring help
The wiring for an OBD1 D15B vtec is identical to a D16Z6 found in the USDM EX//Si, except for the O2 sensor if using a 1 wire unheated O2 sensor, if you're doing this simply use the white wire and depin and tape up the other 3.
ok well acually i am using the d15b as a core, i have to add in the other 3 wires but ok cool thanks for info them being the same i just have to add the 3 other wires for o2 and, turn harness 180 degrees
ok i acually need the pinouts for the shock towers with colors, and labeled, sensor name with color of wires
any body got a link to that stuff
come on no one got the shock tower pin outs for the engine harness, shock tower plugs on both side of bay
