Routing for rear screen washer tube?
My rear screen washer jet has stopped working and I wanted to investigate, does anyone know the routing of it on an 94 civic EG? Im pretty sure ive squashed the tube putting something back.
Thanks in advance
Thanks in advance
Re: Routing for rear screen washer tube?
Bump for an answer! Someones got to have stripped an EG and noticed where the tube goes? After adding a bunch of wiring behind the glove box I believe I may of squashed it. I did try opening the glove box and trying the squirter but no luck. Also ive tried unblocking the squirter carefully with a pin.
Thanks
Thanks
Oh look, I can change this
It's different for RHD EGs, but similar, it sounds like. For LHD vehicles, it runs into the cabin through the firewall, along the driver's footwell next to a bunch of electronics, along the door sill between the sill and the seat, then snakes its way along the rear of the cabin somewhat parallel to the wiring harness.
Thanks for the info. I reckon if i take the glove box out and have a nose about the problem is there somewhere.
