Del Sol DOHC VTEC BRAKE PADS
I noticed that there was a previous posting about this, but I wasn't able to find the answer. I was curious if anyone knew the answer this question. I have a 97 Del Sol DOHC VTEC model. I've been looking for some aftermarket brake pads for it. I was on tirerack and noticed that for the front brakes there was the option for 240mm rotors and 262mm rotors for the VTEC models. I was wondering if n e one knows which one i should get. Thanks for the responce in advance.
Re: Del Sol DOHC VTEC BRAKE PADS
yeah but like on an ex with the larger rotors the caliper is smaller than a teg so it will probably use a different pad, but if OP is on site that gives you the choice, choose the model of your car which you said was the Del Sol Vtec, seems like a no brainer
Seagull Management
'92 - '00EX/94 Si ABS/'99 - '00 Si use one type of pads.
'94 - '97 Del Sol VTEC/'92 - '95 JDM Civic SiR use another type of pads
'94 - '01 Integras (non ITR) use yet another type of pads.
All 3 calipers use the same rotors.
ChrisDaun
03-03-2008 08:38 PM
delsolnewkid
03-13-2006 07:20 AM
rotten
02-12-2004 05:41 PM
