I May Put An 06 RSX Type S K20 Motor In My EG I've Researched Just Need More Info???
I May Put An 06 RSX Type S K20 Motor In My 94 EG due to such a great deal on the full swap through a friend that is only giving me such a deal. I've Researched the stickies on K20A.org and found some info, haven't had much time to search this site, maybe could have found more info but I very rarely have computer time, so all i keep seeing and hearing is something about VSS-(Dont really know what it is) and speed the speed sensor not working different tranny mounts. i know about the drive by wire issue with the throttle body and i keep also hearing about the engine wire harness. Just Need More Info???
All I want is for you guys to explain every issue I need to know & those issues cheapest alternatives????? Sorry I'm a former Bseries & Hseries guy
Re: I May Put An 06 RSX Type S K20 Motor In My EG I've Researched Just Need More Info
um, i have an 04 type S in my EG.
Harness =swap harness
VSS= that IS your speed sensor and that's in the trans, i don't see what the issue is with that*may be something im not aware of* buy a Hasport mount set and it will all fit in fine.
you can use the EG wire for the Drive by wire its just long as hell and i think you get the wire fork that holds it on the Intake from a CRV.. i think.
... ill post a pic later of that stuff.
Drive by wire only comes in 06up si and Tsx motor. The 05-06 rsx-s tranny will work but the vss will not work so your mph gauge will not function.I think the 05-06 rsx tran's vss is internal not like the external vss. Swap 02-04 rsx tranny. 02-04 rsx-s engine harness, hasport sub harness is plug n plug easy. Tsx tranny will not fit the chasiss but they might have made aftermarket mounts for it but not sure yet.
[IMG][/IMG]
there is the TB and the wire and stuff..
as far as the reverse lock out... i've heard of it but i didnt look into it since im rolling an 04.
Check out the stickies at the top of this section on K20A.org: 1992+ Civic EG / DC2 / EK K-Series Swap. It answers your questions about VSS as well as others you may have about swapping your motor into a 92-95 Civic. Good luck.
talks to himself
Didn't read through this thread but here's a link that has a ton of K-Swap info.
http://www.hybrid-racing.com/tech/install-guides/
I feel your pain dude. There's so much to research!! Good luck!
