96 ITR swap in a EG
96 ITR swap in a EG
im helping a buddy put a 96 integra type r swap into his 93 civic Si. its coming with the harness and ecu. i know it theres a obd1 to obd2a ecu jumper but will the engine harness be a plug and plug to the obd1 harness plug for the engine harness? not too familiar with obd2 conversion but since the swap is coming with the ecu we want to keep it obd2 .
Re: 96 ITR swap in a EG
if you have the obd2 engine harness with the motor like you say, then just plug it into the matching ecu. whats hard about that? ur not going 2 to 1 or 1 to 2.
a 96 is obd2 92-95 are obd1
Yes, the OBD2 ITR Engine harness is a 2-piece design that is 100% plug-and-play with the EG chassis. You'll need a jumper harness to plug the ECU in. Easiest swap in the Honda world.
Seagull Management
You'll also want to get an OBD1 alternator and injectors, or cut and splice the plugs from the RHD harness, you could use a chipped and tuned P28 in either case.
Sinner
01-04-2006 05:28 PM
3.point.2
07-08-2004 06:06 PM
JDcompman
04-14-2004 09:33 PM
