Do i need a relay for my kill switch?
I have a 14 gauge wire cut into the ground wire on the clutch interlock switch, which runs to my kill switch grounded to the frame. Do i need to put a relay in? What about a fuse holder?
Re: Do i need a relay for my kill switch?
from what i believe, the starting circuit already has protection (fuse) and you could use a killswitch directly inline with the clutch interlock, given that you use a lower gauge wire (6 maybe 8? idk) and a killswitch capable of handling high amperage
the route of using a relay to control it works as well but IMO is more of a hassle with wiring
but how it'd work is:
pink wire going towards clutch switch = terminal 30 of relay
other end of that pink wire = terminal 87A i think of relay
now the load side of the relay should be inline before the clutch switch
12v positive = terminal 85
ground to chassis = terminal 86
the killswitch and fuse (idk rating) could be on either 12v positive of ground side of the relay
Why would i want to use such a low gauge wire? I understand that it would have more resistance, but current is flowing to the ground (frame of car) in one direction. Whats the problem of using a 22 gauge wire (the same gauge as the ground wire from the interlock switch) to my kill switch (30amp rating)?
I'm still learning electrical theory
I wouldn't use the clutch cancel as a means of a kill switch personally. I would use ignition kill or fuel pump cut. Just my 2 cents
however if you're just trying to add another level to a "theft deterent switch" setup the clutch interlock isn't a bad idea. i used to have one on my last civic. no need for relays, used the same gage wire that the interlock switch uses (16..18?) and never had issues.
Joon Joon
27
10-23-2005 05:49 PM
