How's the a/c in your 5th gen civic?
I would like to know how good (cold) the a/c is in you guys egs my experience so far is they only work good at night and don't do so great during the 100+ degree days here in Texas. I was gonna go thru and replace everything but I'm not sure it's worth it since all the egs I've had the a/c was pretty weak in (I never replaced parts tho)
Any imput is appreciated
Re: How's the a/c in your 5th gen civic?
Start by checking whether the condenser fan runs and the condenser is clogged with bugs. If those are fine, use a manifold gauge set to check whether the refrigerant is low.
Anyway most of the problems I had on previous cars was at red lights...
I am trying to focus this thread in a technical direction as this is a tech forum. The question of whether to rebuild/repair is answered by troubleshooting, as stated in my response. The information you provided suggests that there is a problem with your A/C system. How it is behaving is not normal. The question of ditching is a personal choice and is not technical, which would warrant closing this thread.
mine runs ok
i usually turn it on and crank everything to max, and about 2-3 minutes later i'm nice and cold
to speed things up since everyday after its been outside for a while its baking inside i drive with the windows down and it tends to speed things up
my question/poll is how good does every ones heaters work because mine works amazingly well better then most cars i've been in
heck it was 33 degrees outside and i cranked up my heater in about 3 minutes later i was nearly sweating is anyone elses heater like this or just me?
sorry to thread jack you
