1994 civic has no power like half the power it should have
ok so i have a 94 civic automatic with d15b7 in it. all stock. it does not have any power barely enough to take off from a stop. the timing it all lined up its not out of time. here is a list of things i have done or replaced. coil, fuel filter, plugs, wires, map sensor, o2 sensor. it does not have any check engine lights. if you are driving it and floor it it just bogs down and hardly moves. any ideas???? im at a dead end
Re: 1994 civic has no power like half the power it should have
check your tranny fluid and see if its burnt. might have burnt up your friction disks in your tranny.once its up to speed does it do ok?
adam jeffery
adam jeffery
yes once i do get up to speed it runs fine even at idle it bogs if i just floor it in park just revs real slow i have run out of ideas
Djkevinpaul
21
05-25-2016 07:41 PM
Ehop
11
02-11-2008 10:09 AM
