HELP WITH SLAVE CYLINDER!!
OK I GOT A 94 CIVIC EG AND MY CLUTCH IS ALL THE WAY DOWN ON THE GROUND WHEN STEP ON . BUT WHEN I STEP ON THE CLUTCH AND I NOTICE THAT THERE FLUID LEAKING SLOWLY BEWEEN THE RUBBER PART .SOMEONE HELP I NEED TO GET THIS CAR ON THE ROAD AND SOME DUMMY SAID HE WILL DO FOR 400 LOL..
Re: HELP WITH SLAVE CYLINDER!!
Pretty simple to replace. I would replace both the master and slave cylinder at the same time. Just unbolt the assembly and replace. The master cylinder will need some slight adjustments for the clutch pedal throw. You will need to bleed the lines to get rid of the air bubbles. Mityvacs are the easiest and cleanest way to bleed lines.
You should still be able to drive the car even though the clutch master cylinder is leaking grease. Mine must been leaking the same for a long time before I replaced it. Like stated above, buy both the master and slave cylinder and just bleed the system.
Be careful putting the new slave cylinder not to mess up the rubber, did you just put a new one on it? Or is it just old and started leaking?
nonvtec92
06-22-2007 05:04 PM
-BlueGSR-
12-21-2002 07:30 AM
