brake swap
brake swap
Hey guys, whats up?? Need some help, I'm about to buy a GSR brake swap, front and rear, for my 00 Honda Civic but was wondering if anybody knows if I need a different axle for the front to fit or if its just a straight swap. Thanx guys!!
Re: brake swap
The outer axle shafts are the same size, so you will be good. However, you may need to do a proportioning valve change depending on what model civic you have. Also, GSR brakes are no larger than other integra brakes. The only larger integra brakes would be those from an integra type r. What model civic do you have exactly?
Re: brake swap
Actually, the Integra does take a larger front pad than any model Civic. However, my comparison shows that the piston diameter between calipers is the same, thus the effective braking force remains the same.
Re: brake swap
I know the ITR / Civic (EX / Si 99-00) share the same piston size, I literally matched them up next to each other.
So maybe that's what I was thinking about instead.
streethondar
01-13-2011 05:49 AM
Sifu
04-26-2006 12:24 PM
ImportechPerformance
08-25-2005 04:19 PM
99civic_exSB
05-29-2003 06:55 AM
