my little f swap dilemma
Old 04-02-2011, 07:27 PM
upgrayedd's Avatar
Default my little f swap dilemma
going to explain in photos,
the dirty car
engine going in it
stock f23 post
stock f23 post with my hswap mount on it
h swap mount lined up with H22 post
h22 post on f23 block
if h22 post wont bolt to the f23 block, how do i f swap my car?
upgrayedd is offline
Old 04-02-2011, 07:43 PM
Default Re: my little f swap dilemma
Will the OEM mount fit?
Would a F22 bracket work? Is it any different?
I know a lot of people just do an H2B/F2B swap to eliminate most of the headache. Use B/D series mounts, the B trans, B linkage, B axles, B clutch. The only part that's a hassle is the header.
NotAJDMFanBoy is offline
Old 04-02-2011, 07:48 PM
mavvrik's Avatar
solution= stick with B or D in a civic. Eliminates the headache all together
mavvrik is offline
Old 04-02-2011, 07:54 PM
upgrayedd's Avatar
this has nothing to do with the trans. even if i was going f2b id still be having this issue.
Old 04-02-2011, 07:55 PM
upgrayedd's Avatar
you've contributed nothing to this thread. your post is null
Old 04-02-2011, 07:57 PM
mavvrik's Avatar
Well than ignore the comment and move on
But on a serious note, i thought you had to use H mounts. Could be wrong though
mavvrik is offline
Old 04-02-2011, 08:01 PM
upgrayedd's Avatar
thats what i thought. but apparently we are wrong.
Old 04-02-2011, 08:04 PM
mavvrik's Avatar
i dont know a lot about this swap but as far as i know its exactly like a H swap except one mount is deferent. Im not sure what mount to use but ive heard some reall effin horror stories about obtaining it
mavvrik is offline
Old 04-02-2011, 08:09 PM
mavvrik's Avatar
Im pretty sure hasport makes the mounts exactly for a F23 EG swap
mavvrik is offline
Old 04-03-2011, 08:46 PM
upgrayedd's Avatar
the F23 is strictly temporary, building this for frankenstein at the moment
Old 04-03-2011, 09:07 PM
Actually, it does. H2B tilts the motor forward so it sits up like a B/D series instead of being tilted back as the F and H series do normally. When you do this, you use the B series mounts. This is why I asked.
I have somewhat of an interest in the weird things Honda did and solutions to these odd issues that arise.
Old 04-03-2011, 09:10 PM
SeanK325's Avatar
according to the site, they only make D, B, H, K, J for the EG.
SeanK325 is offline
Old 04-03-2011, 09:42 PM
mavvrik's Avatar
Hasport H-mounts are the ones that fit i believe
mavvrik is offline
Old 04-04-2011, 03:58 AM
hondamark35's Avatar
Why not just use that H22 bracket you have on the F23 block...?
hondamark35 is offline
Old 04-04-2011, 11:01 AM
upgrayedd's Avatar
the bolt holes dont line up and the post hits the cam gear.
see photos
Old 04-04-2011, 11:18 AM
The Grumpiest
grumblemarc's Avatar
Everything says the H22 mounts work. However I found this.
Originally Posted by high_revs View Post
...you need a 90-93 drivers side mount post...
I'm assuming the post is from an Accord.
grumblemarc is offline
Old 04-04-2011, 02:20 PM
see photos
i'm looking at the 5th image where the bolt holes line up. i guess then last image is where it's hitting the cam gear..? just grind it down for clearance...
Old 04-04-2011, 06:06 PM
upgrayedd's Avatar
Originally Posted by grumblemarc View Post
Everything says the H22 mounts work. However I found this. I'm assuming the post is from an Accord.
thats what i thought. thanks dude
Old 04-04-2011, 09:19 PM
EK-ek's Avatar
let us all know when you find out! this thread is helpful
EK-ek is offline
Old 04-06-2011, 09:28 AM
SQ is the SQUAD's Avatar
contact greg at go autoworks, i belive he was making an adapret bracket for a h2d or somethnig like that, looked like what you need
SQ is the SQUAD is offline
Old 04-12-2011, 10:17 AM
upgrayedd's Avatar
got it figured out, 90-93 accord bracket bolts right up, clears the cam gear, and takes the hmount.
Old 04-13-2011, 10:20 PM
upgrayedd's Avatar
raddd
Old 04-15-2011, 06:23 AM
EK-ek's Avatar
sweet thanks man! how does it run?
EK-ek is offline
jdm 1080p
10-08-2012 03:27 PM
hafftrak
01-13-2006 03:29 PM
JCracer723
12-12-2005 07:16 AM
rkn527
03-30-2003 04:03 PM
Quick Reply: my little f swap dilemma
  • Ask a Question
Question Title:
Description:
