S2000 Steering wheel into an EG or Del sol
Enjoy! :D
Update!!: FIRST! Disclaimer: I, and Honda-tech and it entities or persons submitting the information here will not assume responsibility, nor be held liable for damage resulting from the use or misuse of any information contained on this page/s. In other words, any information you find here is to be used at your own risk. This rewiring procedure does not set a SRS light code after the self tests however It has not actually been tested in a real world accident or test accident. This does not guarantee normal operation of the airbag system.
Finally.
To rewire the airbag system. All I did was remove the pins from the connectors
on each air bag and swapped the connector from the Del sol's airbag onto the
S2000 air bag. You'll want to cross the wires when reinstalling into the connector.
The Pins were the same so they snapped right in. Reconnected
everything and BAM! No SRS codes. Light turns off several seconds after
engine on.
Finally.
engine on.
Re: S2000 Steering wheel into an EG or Del sol
Very easy swap. Shouldn't take you more than 1-2 hours depending on how long it takes you to reweld that bracket onto the column.
Is the steering wheel plug and play for a 96-00 civic?
ZacinStLouis
04-08-2011 09:38 AM
