My ZC 1997 p2a parts gathering
know its the main bearing code
thanks to the donors
Motor came from a 1997 integra ZC db6 sedan... i helped the owner pull out the engine out the car but he up the engine and have the parts laying out so i decided to take it and use as an experiment and learn about d16 ZC
1600cc 120hp factory specs
the reason why he change the engine cause it was a bit smokey in the top end revs with brand new rings
he swap to a new zc with gearbox swap
so this becomes my little experiment project... the owner said he is kinda pissed off he opened the engine because he wanted to give me it working so i put it in a shell and
drive
If you curious whats in the background its a 4afe project from june last year i restored it i got it from a friend and the tranny is from dads camry a140 just needs some clutches
but the light is on the ZC now i will buy a short block in the future and bolt on my parts.. oil pan and head
getting the parts on the block
the Suspension
valve cover removed for clean for paint
More parts came in
got a 2001 civic converter to replace my 1997 one the part numbers different but it looks same externally
Need a tranny now
washing the a140e tranny with gas
my inspiration magsi read daily
a honda link up the 27th of may
Camshafts 5afe exhaust,4afe intake,sr20de intake and ZC obd2 full
sr20de low port
torque converter clutch flushed and ready for the road
4afe getting compression my experiment engine
4efe manifold got cleaned up
ZC camless no internals
d17a vtec stream at the garage changing the tappet cover gasket
badass non vtec cam
I need a daily driver now gosh too much parts and no car
Seagull Management
Re: My ZC 1997 p2a parts gathering
OP, is this going somewhere anytime soon? Because right now it just looks like a bunch of parts that quite frankly has no tech whatsoever.
saving to buy a ef then drop the ZC with a new tranny inside it
getting a deal on a 1985 civic rolling shell with glass and documents i not sure if i must take it
also getting a deal on some LS rods the seller told me it can fit my crank
i want to change the thread title to ZC build
what people cant see is that i got this engine parts so it putting it together alot a bolts and nuts where missing so i go to garages and get some
yup soon throw away the flex plate and torque convertor...some honda parts hard to find and get in jamaica since we dont have big junk yards like USA we can pick out some parts
i hope in can buy a honda with a gearbox and just swap engine its easier that way old EF or so i dont care about looks i enjoy honda engine
thread can close or delete now i gone d15b pm3 short block with the zc head high compression
https://honda-tech.com/forums/forced-induction-16/d15b-pm3-full-zc-97-head-10-5-1-cr-2975485/
