Weird Clutch Noise?
Old 04-19-2012, 10:12 PM
Tman6925's Avatar
Default Weird Clutch Noise?
Hello all, looking for some feedback to help me figure out what is going on with my car. Prob around 2000 miles I replaced my clutch/flywheel for my gsr tranny with a comp clutch stage 1.5 and a lightweight comp flywheel. Everything was smooth and fine until the past two weeks, when i push my clutch in 100% makes a whining type of noise and its really hard to put into gear, but if i push the clutch like 95% or little less there is no sounds and shift like butter. Someone said throwout bearing but i put a new one in during the install, i haven'e seen any leaks in the lines or master/slave cylinder either. Another guy suggested i adjust the clutch pedal height. But I think that would just be covering up the problem, anybody got any ideas or experience with this. Thank you for your time.
Old 04-19-2012, 11:11 PM
R.I.P. Mark
MRGRIM's Avatar
Default Re: Weird Clutch Noise?
clutch pedal height ..NO
clutch pedal throw ..YES
sounds like your pushing it to far
bleed the clutch and then set the pedal throw via the shaft
( shaft from pedal to clutch MC )
Old 04-19-2012, 11:34 PM
Tman6925's Avatar
Ty for the reply, I honestly didn't know you could "push it too far" I'll look up how to adjust that then see how it goes :D much appreciated.
bbrian
Transmission & Drivetrain
06-14-2013 10:09 AM
megaman096
11-08-2004 11:26 AM
jdmcivicferio
07-09-2004 02:15 PM
eh-D
05-12-2002 10:00 AM
Quick Reply: Weird Clutch Noise?
