95 EJ2 rywire engine harness through firewall
Searched, couldn't find anything that helped. I'm trying to run my engine harness through the firewall to the ecu. I can't find a spot to route it and I'm getting frustrated.
I've tried the passenger side hole that has the fuse box wiring. It's too tight to fit the connectors through. Also tried the drivers side hole with the same issue. Where do I route this thing? Such a PITA. Don't want to have to take off the entire dash, but I cannot fit my hands behind all the **** there. Thanks in advance.
R.I.P. Mark
Re: 95 EJ2 rywire engine harness through firewall
search this thread its your best bet for options
https://honda-tech.com/forums/showth...3934&page=1291
I'm not going to de-pin every single clip so I can route it through and re-pin it. Also, I have contacted rywire. I've figured it out myself though. For those who may run into the problem later, if you don't have ac remove the evap box and route through there. It is much more simple than it looks. All the clips will fit through either way. No real fighting with anything. May be different for EK's though. Not sure how the firewall is on those.
lolv8s
05-17-2013 05:20 PM
07BBS2K
08-03-2010 02:43 AM
RicedREX
13
04-20-2005 06:46 PM
SkRiBLaH
14
12-26-2004 08:35 PM
