95 civic dx 200k+ maintenance
What's up everyone?
I have a 95 civic dx with 213k miles.
This weekend I'm going to be changing the timing belt, water pump, and thermostat. Is there anything else I should be changing?
Thank you.
Thank you.
Re: 95 civic dx 200k+ maintenance
Spark plugs, air filter, cap & rotor, valve cover and oil pan gasket, distributor external o ring, oil change, transmission fluid change, et
I've recently done the spark plugs, air filter, and cap & rotor. I'll be sure to do the rest of that stuff. Thanks!
I'll check these out too. Thank you every one.
The plan is to get a newer car in the next few months so I want this car to last me until then and all make it easier to sell when I finally do get a new car.
dont change rad hoses unless it feels to soft or squishy when squeeze. change your cam and crank seal while your timing is out, valve cover gasket.
Brandon Beja
11
12-21-2017 10:50 AM
