need help changing bulps
need help changing bulbs
tried to search, don't know what it's called so i didn't find much, can anyone link me a diy write up on how i change the bulbs in this:
Re: need help changing bulps
if its the same as in our tahoes on tyf then u need to desolder the bulb and solder new bulbs in. i would go ahead and do led since ur already gonna have to do some soldering
R.I.P. Mark
the globes are not soldered in
1 take out radio
2 pop out the two switches hazzard and dimister and unplug them
(use a tiny flat screwdriver in the corner to pry out)
3 behind the switches the is a screw
4 *remove the lower cover under with asstray*
remove the glovebox 2 screws under the hindge
remove the underdash panel below steering wheel 4 screws 1 at each corner
you then have to pull the cover off as it has clips
now the lower ashtray caove has 4 screws 1 at each corner an one in the ashtray( look up inside)
5 2 screws just under the heater control behind where the ashtray cover was and
1 screw right at the back you might find it easyer later as it will be the only one left
6 disconnect the heater cable from the heater valve in the engine bay its just a clip
7 now carefuly pry the the whole dash facia surround off it has clips
2 clips above each vent these are the easy ones mostly will come out on there own
1 clip each side level with the clock buttons
1 clip in the middle at the bottom
8 unplug the heater control, clock
9 now the heater control has 4 screws at the back holding it to the facia
10 pull the 2 slide ***** off
11 the face of the control has little clips all the way around carfully pry them loose
this is where you will find the bulbs/globes inside
hope this helps
here is a link to the exploded veiw of the heater control
http://www.hondaoriginalparts.com/ho...block_03=11545
1 take out radio
hope this helps
Jettplane
06-12-2012 08:28 AM
I LUV MY EJ1
10-21-2008 08:37 PM
J337_UNIT
06-08-2003 09:13 PM
Tomek
10-05-2002 05:46 AM
