CP sensor & Knock sensor.. Important?
coolant temp sensor/gauge problem..
Just bought a 00 ex & the check engine light is on. Autozone scanned it & came up crankshaft position sensor, knock sensor & coolant temperature sensor bad. I had actually just replaced the coolant temp. sensor before getting there so don't know why that came up. Anyway, do I have to replace the other 2? If it's not necessary then I wont because the knock sensor is 135.99.
Also I should say that the temp gauge on my cluster moves up about a quarter inch to the first line, even when warm it won't go up any further. I changed the coolant temp sensor, might the t-stat be bad too?.. This I do need to fix. Any input would be appreciated.
Re: CP sensor & Knock sensor.. Important?
fix them all. or you'll be running around with a check light on all the time. and you'd never know when you get a new one.
it might be expensive but consider the one in there is 15-20 years old.
So far I've replaced 2, the knock sensor & the coolant temp sensor but my temp. gauge still doesn't go up past the first line even after I pulled the ecu fuse & did the reset routine. Could the t-stat be stuck open & if so wouldn't that have shown up on autozone's scanner?
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
I had this issue on the 98, get a dealer temp sensor first, none of the aftermarket ones I found were the correct ohms range to make the gauge work right, I have a collection of about 7 of them, all supposedly for the same car, and none the same. If this doesn't work, the cluster has a voltage regulator built into the circuit board that controls voltage to the gauge, theres a good chance it's bad, stock clusters are usually all over ebay and the yards for cheap
I haven't swapped it out. I just bought the car & replaced the coolant sensor because it threw a code for it.
There is no code for a bad thermostat, if your not getting heat yours is bad. Replace it, that should still not give you a code for coolant temp sensor though. Check and make sure all the wires and connections are good, or find what the factory resistence is supposed to be and ohm your new sensor out
Good to know, I thought it would have thrown a code. I'll replace the t-stat tonight, I have a feeling this is the problem.. Crank position sensor will get swapped out tomorrow & that should cover all my codes.. hopefully
Technical Hero
Wait what crank position code do you have? The crank position sensor on your car is in the distributor and is not replaceable, you have to replace the whole distributor. Can you take a pic of what temperature sensor you replaced? One is for the gauge and one is for the ECU. Post the exact codes you are throwing, should be this style ie P0420, or count the number of blinks by jumpering the service connector.
Im not changing the CKF, if I get a year out of this motor Im happy. I just want the temp. to run right!
there are two temp sensors, the one for the gauge will have a single wire and looks like the older sensor,only bigger, I used to have the ohms range written down, but I can't find it, I ordered a sensor from everyone I could, and none of them were right, just stick with the factory sensor, the other one that throws the code is a two pin sensor with a plug, thats the one that will throw a code, if you need one PM me, I have a brand new one of those from Nappa, I think I screwed it in and the plug wouldn't lock in place, or something stupid, it will plug in though, you can probably work around that. I no longer have the car and don't need it. The one that runs the gauge doesn't connect to the computer in any way. If the engine is running rough or has a miss, you will get that crankshaft fluctuation sensor code, it's saying that the crank isn't rotating smoothly but is erratic, anything that causes a miss will trip that code.
if that coolant temp sensor for the computer isn't working it will cause the car to run badly and could trip the other codes
check the thermostat and then let the car idle with the cap off and make sure coolant actually flows, I had a water pump that failed and caused that
Wow good info. The temp sensor I replaced is the one with 2 prongs & I got it from car quest, it also doesn't lock in place but plugs in. I bought the t-stat and will be changing that out today, if that doesn't work than I'll get a temp sensor from the dealer. Im going to reset the ecu after this & see if the codes come back.
Re: coolant temp sensor/gauge problem..
You need to fix them all. Both of those sensors will cause the car to run in limp mode. that means no VTEC and retarded timing. This will cause poor acceleration/performance and bad gas mileage. YOu might be able to go to a junkyard to find the knock sensor though, but either way you will need to get one. You can check and see if yours is bad, it might be possible that it is disconnected or there is a problem with the wire. If you have another car to test it on I suggest you do that, as it is a expensive sensor.
