99 Turbo civic steering problem?
Just bought a 99 si turbo.........whenever i give it some gas the car will swerve to the right and very hard to control....i dont know why..........alignment is still good, car doesnt swerve or nothing while cruising......car have no power steering fluid.........Has skunk2 lower control arms....maybe previous owner didnt install the control arms right? Also have skunk2 coilovers and is dropped pretty low......think is should raise it back up and get alignment? ANY HELP OUT THERE!....THANKS ALOT
Re: 99 Turbo civic steering problem?
Can't see under your car so I suggest you jack it up and check for play in your tie rods, ball joints, upper and lower bushings. It also sounds like some torque steer but it can probably be drastically worse with bad steering/suspension components. If it looks worn replace it. Almost every steering/suspension component in the front end can be replaced with new stuff for around 200. It just takes awhile.
If the steering problem is bad enough to ask about it then its probably a shot rack and pinion , inner tie rods.
When I had that problem I would accelerate and have to compensate the torque steer then when I went to brake I had to real compensate it going the other way.
Lift the car up and check out your inner tie rods, check for play.
I would usually agree with torque steer, but he's saying it's pulling "back and fourth". Torque steer doesn't do that. OP, there's something wrong in your steering. Check EVERYTHING for play.
96hb
Suspension & Brakes
40
02-05-2013 12:16 AM
Drop_A_Dookie
12
02-13-2011 07:56 PM
