Del sol clutch problem
I replaced the clutch on my sol because i thought it was slipping. So I replace my clutch on my d15 del sol and resurfaced the fly wheel and all that . So I have had it on my car on my car for a month and in order for the clutch to engage I needed to take the clutch almost all the way out and when I'm on the highway for a while and downshift to go up a hill it seems to slip and just rev up and I have to let go of the gas so it can engage again . Help on what it could be :/
Seagull Management
Re: Del sol clutch problem
No it couldn't. Nor could it be the slave cylinder. They only release/disengage the clutch.
If it's slipping it's worn past the service limit, or it's contaminated with oil/grease/transmission fluid etc. I don't suppose you have picture of the clutch you replaced?
I don't know we're it's at at the moment but it still had life and don't see why it would slip.
Well when I replaced it I made sure everything was clean and put the cover back on the transmission . Unless my tranny is going out ?
The Grumpiest
Now we're jumping to the transmission? If the clutch is slipping then it's the clutch. That is, unless you don't actually know what a slipping clutch actually feels like. I say this because you say it "seems" to slip. Trust me. If your clutch was actually slipping, you'd know it.
The Grumpiest
There would only be two reasons. Both of them listed in post #4. If you didn't break the clutch in properly you probably glazed it all to hell. Either way you have to pull the transmission to inspect.
drlagares
18
05-30-2015 03:46 PM
