installing a new slim fan
okay so yesterday my stock fan went out on my del sol,so im ordering a blox slim fan.im wanting to put it on as a pusher so which way should the fan blades be spinning??any help would be be appreciated
Re: installing a new slim fan
it can be hooked up to push or pull whatever way u decide to mount it. if its blowing the wrong way as grumble said swap the wires and it will spin the right way. you can always test what way to hook it up on your battery temporarily and figure out what way to connect it. i recommend using the plug or wires coming from your OEM fan so it runs off the stock fan switch.
thanks for the help and info guys
this morning i got woken up at 8:30 by my doorbell and found this
and then i opened it and found this
and now my car looks like this and is running again and i got the fan pushing the air into the radiator
^^Looks good.
Straight blades? Then just reverse polarity.
Curved blades? I believe you have to remove the blade, flip it upside down and then you are good (no wiring changes).
I have been running a straight blade fan as a pusher for years with no problems.
What do you mean how does it run like that? Is it a fan. The angle of the straight blades changes how air is affected if the fans spins differently.
Spin one way and it will push, spin the opposite way and it will pull.
I just said I have been using a fan like this for years. Why would you then ask if we are having any problems with it. Obvious answer is obvious.
Doh!
07-03-2006 09:29 PM
Manual radiator Fan switch help! electronic gurus needed....tried search...but need more info\help..
Project_ED8
12-01-2003 05:50 PM
