OBD1 92-95 jdm b16a swap into OBD2 2000 si - Will it run?
I just bought a 2000 si w/ a jdm 88-91 b16 (obd0) but its running the stock 2000 si ob2 wiring harness and it ran till I drove it in the rain and my aem cai sucked up water and the engine cracked 2 rods in half. Im buying another 92-95 jdm b16a which is obd1 BUT i have the stock obd2 wiring harness. My question is, If i bolt up the engine and plug everything up, Will it run ?
Re: OBD1 92-95 jdm b16a swap into OBD2 2000 si - Will it run?
bought it with the same engine failure
And to answer your question
I would assume before the hydrolock inccident that all was well, motor made decent power, no faults (CEL) ect.
You would simply replace the long block assy. and use the sensor/wiring setup that was being used with that older motor.
On the good side you have a little more pinch of power out of that sir2 motor for sure compared to the old salty B16.
And the butt dyno will notice.
Cool Cool Island Breezes. BOY-EE
Yes. The OBD1 engine will bolt in. Your harness will plug into it. It will run. Re-use your OBD2 distributor.
Im was running the stock 99-00 Si obd2 ecu with my obd0 b16 that got hydro locked and it ran. I'm assuming the 92-95 sir2 motor will run as well? Thanks alot guys
****, how can I identify my injectors? I have no idea if the people who owned the car before me used obd0 injectors or if they used the stock obd2 injectors
What do I do about the crank sensor on the obd2 wiring harness?
well i just figured out that the 92-95 jdm b16a doesnt use a cranks sensor so i had to put my b16a2 crank sensor in the block, im guessing i have to swap my b16a2 manifold as well cause the 92-95 model has an extra sensors on the throttle body and also on the intake manifold, all this so i can run my obd2 wiring harness. has anyone swapped a 92-95 b16a into a em1? if so, what changes did you have to make? (without converting to obd1)
NOman0608
05-12-2007 08:39 PM
ScottEK
01-24-2004 11:09 PM
