speedometer/odometer problems
i got 95 dx hatch with stock 5spd motor and all the regular electronics.
tonite while out cruising my speedometer jsut stopped working and sat at 0mph for a good half hour or more. shortly after the odometer stopped keeping track of the mileage. i was sitting at 97600 miles for probably a good 10-20 miles. think this could jsut be a short or something? anyone whose had this problem and fixed it please tell me what you did. tomorrow i'm planning on taking a look at all the wiring and sensors and if all else fails may call honda since i dont have to cash to get raped by them for staring at it for hours on end. thanks for any help.
later
later
Re: speedometer/odometer problems (95dxhatch)
vehicle speed sensor, or VSS.....it is located ON YOUR TRANNY, and it should have 3 wires going to it......just unplug the harness and clean it up with an electrical cleaner, and clean the INSIDE of the tranny-mounted harness with the same stuff....
once you do this, the problem should disappear....the only other thing that it could be is a bad VSS.....they arent hard to replace at all, and can be had at a junkyard for like $10-20
good luck....i had this SAME exact problem.......i just rode it like that for like 3 weeks heheh....just to save miles, then i fixed it
Re: (SpoonFedHatch)
werd,..i degreased my motor this weekend,...speedo acted funny,...traced it to the VSS,..i let it dry out,..and now the orange needle works like a champ now,...i asked fellow members a question i already knew and they said the VSS also
Re: (WiDeBoDyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK »</TD></TR><TR><TD CLASS="quote">werd,..i degreased my motor this weekend,...speedo acted funny,...traced it to the VSS,..i let it dry out,..and now the orange needle works like a champ now,...i asked fellow members a question i already knew and they said the VSS also </TD></TR></TABLE>
same thing happened to me when i cleaned my motor, damned VSS
to H-T for helpful tech info
Re: (opi)
Hmmmmmmm, mines gets jumpy from 40mph to 60mph....likes it goes up and down and then I give it a lil gas and it goes back to normal....I'll have to check it out........brake cleaner okay to use???
petr0lb0mb
23
03-22-2017 01:41 PM
SlowSOHC-T
24
02-26-2006 03:25 PM
DestructoEH
09-03-2005 10:44 AM
