which brake m/s and p/p valve
anyone know which brake master cylinder and proportioning valve im supposed to use with 96 spec typeR f/r disc brake conversion? I think i can use both from a gsr,
but correct me if im wrong. thanks
Re: which brake m/s and p/p valve (EGgwhite)
I have a GSR ABS one which requires bending and flareing. Also a GSR booster to bolt it up to. There are other solutions, this is just one so someone else will post more.
I have a stock prop valve, but the 30/40 or the 40/40 is one you want, depending on your car find one from a model that has rear disc. For EGs you can use the Si model's prop valve, its about $120 from a dealer new.
I would use the stock prop valve and just upgrade the m/c to a 15/16" 91 EX four door one if you have a 5th gen.
4040 is overkil without the abs IMO. Don't forget to get some SS lines while you are redoing your brakes.
big strong guy
Re: which brake m/s and p/p valve (B.CRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.CRUZ »</TD></TR><TR><TD CLASS="quote">I would use the stock prop valve and just upgrade the m/c to a 15/16" 91 EX four door one if you have a 5th gen.
4040 is overkil without the abs IMO. Don't forget to get some SS lines while you are redoing your brakes.</TD></TR></TABLE>
Why leave a Prop Valve that is designed for rear DRUM brakes on a car that has added rear DISK brakes
Get the SI (92-95) Prop Valve as it has no ABS
And read Toms artical on EG's Easiest MBC upgrade!
https://honda-tech.com/zerothread?id=364783
Eric
Eric
redsikiller
11-08-2005 03:58 PM
sal_blkej2
11
04-17-2004 07:22 PM
