Swap question about purge tank
Old 05-27-2003, 08:55 PM
monicle's Avatar
Default Swap question about purge tank
Ok heres the tank from my 2k civic HX the question is what I do with the hose.
On the fuel rail here is the purge valve or whatever that it connected to.
But on the b18c I have there is no valve.
Ok so heres my question. Obviously I wont be using the valve but what should I do with the hose on the tank? should I find a way to plug it or what?
Old 05-28-2003, 03:29 AM
monicle's Avatar
Default Re: Swap question about purge tank (monicle)
bump
Old 05-28-2003, 06:59 AM
Rowdy's Avatar
That canister is M.I.A. from my car,unused and sits in my garage.
(After the obd-1 swap).
I think its the charcoal evap system,(mainly for a clean running emissions passing ride).
Old 05-28-2003, 07:04 AM
monicle's Avatar
Default Re: Swap question about purge tank (Rowdy)
what did you do? just cap off the hoses that went to it or what?
Old 05-28-2003, 07:06 AM
Rowdy's Avatar
i'll post pics when i get home after work (8/9 hours).
Yes, capped off the lines.
Old 05-28-2003, 07:23 AM
monicle's Avatar
Default Re: (Rowdy)
cool ill check back on it. thanks for the help.
Old 05-28-2003, 07:51 AM
Doctor CorteZ's Avatar
throw that **** away and plug the hoses , all it does is filter vapors from the gastank , leave the vent tube open and plug the other vacuum lines.
Old 05-28-2003, 10:29 AM
Rowdy's Avatar
Default Re: Swap question about purge tank (Doctor CorteZ)
Actually, you wont need a pic now.
Just do what was suggested above ..thats how i have it.
Old 05-28-2003, 10:57 AM
monicle's Avatar
which one is which?
Old 05-28-2003, 12:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">which one is which?</TD></TR></TABLE>
just look at it , you can tell what needs plugged and what comes from the fuel tank.
Old 05-28-2003, 12:27 PM
Nextelbuddy's Avatar
u really dont need it but if u must have it then common sense should kick in and u can see what has to be plugged up and what doesnt.
NathanMorris
08-02-2007 07:52 AM
BlackBeastEK
04-01-2007 09:26 PM
DutchITR1689
09-28-2004 12:43 PM
Quick Reply: Swap question about purge tank
