Complete LS into a 94 DX swap guide
Old 05-27-2003, 07:07 PM
madhatter07's Avatar
Default Complete LS into a 94 DX swap guide
hey guys i know i saw a complete guide that had all the wiring and that kind of stuff somewhere and im gonna be dropping in my engine in a little while, its a B18B1 and its going into a 94 DX so i need a little bit o help on this one, thanks a lot guys, and i tried searching but i was ultimately unsucessful
Old 05-27-2003, 07:10 PM
Adriano's Avatar
Default Re: Complete LS into a 94 DX swap guide (madhatter07)
if the motor/tranny is from a 94-95 integra, it should be a direct swap. No extra wires will be need. You can your stock or b18b1 harness. it will be a plug and play
Old 05-27-2003, 07:25 PM
Default Re: Complete LS into a 94 DX swap guide (brryder)
what if its a civic Si tranny? also im kind of embarrased to ask this but how the hell does the transmission hook up to the driveshaft and please do not make fun of me for that, i am trying to gain experience by doing the swap myself so give me a little credit
Old 05-27-2003, 07:28 PM
Slow CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madhatter07 &raquo;</TD></TR><TR><TD CLASS="quote">also im kind of embarrased to ask this but how the hell does the transmission hook up to the driveshaft</TD></TR></TABLE>
No driveshaft. Just axles, they go in the holes on the sides of the tranny. Pass side is the longer axle, shorter one is driver side.
Adriano's Avatar
unless you have a custom RWD/AWD civic, you dont have to worry about the driveshaft. You will need 94-01 integra or 99-00 civic si axles and shift linkage. The b16-hydro tranny and b18b1 motor will bolt right in.
Old 05-27-2003, 07:32 PM
lol driveshaft, i told you i didnt know much about swapping
edit also:
how do the wires from the engine get down to the ECU?
Old 05-27-2003, 07:47 PM
95hbMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madhatter07 &raquo;</TD></TR><TR><TD CLASS="quote">lol driveshaft, i told you i didnt know much about swapping
edit also:
how do the wires from the engine get down to the ECU?</TD></TR></TABLE>
The wires are already there....the engine wiring harness "plugs" into the chassis harness which then plugs into your ecu. There is a set of gray plugs on the left side of your engine bay which leads through the firewall to the ecu.....
Old 05-28-2003, 08:31 AM
Default Re: Complete LS into a 94 DX swap guide (95hbMatt)
alright awesome, thanks a lot guys, hopefully everything will go according to plan
Old 05-28-2003, 10:38 AM
Banned
Burke's Avatar
what about the o2 sensor?? your dx is 2 wire and b18b is 4-wire?
i have the same question, which is why i am asking
thanks
Old 05-28-2003, 10:59 AM
95hbMatt's Avatar
Default Re: Complete LS into a 94 DX swap guide (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">what about the o2 sensor?? your dx is 2 wire and b18b is 4-wire?
thanks</TD></TR></TABLE>
The O2 on my DX is a 4 wire. works fine.
Old 05-28-2003, 11:21 AM
mrpeabody's Avatar
You could also use your civic wire harness it is the same setup, the only thing is the o2 sensor wires are shorter...
Old 05-29-2003, 07:13 PM
Default Re: (mrpeabody)
oh shat now im confused, do i need some different parts? also another newbie question, what the shift likage hook to? im assuming the shifter and the transmission right?
boostdvic
12-01-2008 05:50 PM
Tarzan
07-21-2006 04:02 AM
NA-Cutie
01-11-2005 09:41 AM
nasteboyii
11-17-2003 04:33 PM
civic311
02-26-2003 07:33 PM
Quick Reply: Complete LS into a 94 DX swap guide
