B16Bin a 95 civic?
Re: B16Bin a 95 civic? (allmtr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr »</TD></TR><TR><TD CLASS="quote">yes there is a harness. im using one right now. </TD></TR></TABLE>
it would of helped to let him know wut harness...
Re: B16Bin a 95 civic? (89_CRX_HF)
OBD1
Courtey of Katman
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A4-VTS VTEC solenoid
A5-INJ3 INJ3
A6-PO2SHTC O2 sensor (heating element)
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A12-FANC engine coolant temp switch
A13-MIL MIL (check engine light)
A14-empty
A15-ACC (a/c compressor clutch)
A16-ALT C alternator
A17-IAB IAB Solenoid
A18-empty
A19-**
A20-PCS EVAP purge control solenoid
A21-ICM ICM
A22-empty
A23-PG1 ground
A24-PG2 ground
A25-IGP2 to main relay and to gound for o
A26-LG1 gound
B1-IGP2 to pin A25
B2-LG2 ground to shields for CYP & TDC
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B9-STARTER SIGNAL starter signal
B10-VSS vehicle speed sensor
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D1-VBU Back Up Power
D2-BKSW brake switch
D3-KS Knock Sensor
D4-SCS service check connector
D5-empty
D6-VTM VTEC pressure switch
D7-TXD/RXD (data link connector)
D8-empty
D9-ALT F alternator
D10-ELD electric load detector
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
Re: B16Bin a 95 civic? (EK-TUNED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TUNED »</TD></TR><TR><TD CLASS="quote">
it would of helped to let him know wut harness... </TD></TR></TABLE>
he didnt ask my friend made it. goto a local shop and they can order one for you.
ok, you wont be able to use the harness that comes with the B16B, so youll need to use the wiring harness from your stock motor...if your car is an EX/Si, its all plug and play, if you have a DX/CX/LX, youll need to run your own wiring in order for the VTEC system to work, which that diagram shows you how to do it
your also gonna need a obd1 ecu like a chipped p28, then your stock wire harness will work fine, also your gonna either need obd1 inectros and distributor unless you know how to change the plug and or modify
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_CRX_HF »</TD></TR><TR><TD CLASS="quote">Why a chipped P28 Why can't I use my stock p28 that I have for my Z6.</TD></TR></TABLE>
sure if you want it to be slow, cant run a dohc vtec motor properly with a sohc ecu. you would redline at 7200 which would be very gay
Location: Toronto, Canada currently residing in ATL, GA, USA
YOU CAN USE THE HARNESS THAT COMES WITH THE MOTOR PROVIDED ITS NOT CUT. Jesus I don't know how many times I've said. I'm using a JDM ITR harness and have been using it for the last 2 years.
Re: B16Bin a 95 civic? (Apex i ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR »</TD></TR><TR><TD CLASS="quote">YOU CAN USE THE HARNESS THAT COMES WITH THE MOTOR PROVIDED ITS NOT CUT. Jesus I don't know how many times I've said. I'm using a JDM ITR harness and have been using it for the last 2 years.</TD></TR></TABLE>
seein that the b16b came out of an ek civic and that the motor is goin in a 95 civic.
its not gonna be plug and play. he can either modify his civic harness or just use a obd1 or obd2 gsr harness and use a obd 1 b16 or gsr ecu and not to forget he can also use a properly chipped p28 for b-series.
p28's can be found here.
http://www.hyperducktuning.com/
Post a pict to prove it. I have a JDM EG6 harness and there is no ******* way it is going to plug directly into a USDM 92-95 harness.
Re: (lazyvietboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyvietboi »</TD></TR><TR><TD CLASS="quote">What tranny do b16b's use?</TD></TR></TABLE>
i believe it s similiar to a us spec itr tranny if not the same.
but then again i can be wrong.
go this page and you can compare gear ratio's
http://tech.hybridgarage.com/tech/bseries.html
dejavu247
12-31-2007 07:33 AM
