car looks "lifted" after rear swaybar install
I just put a 14mm gsr rear swaybar on my eg hatchcrap. After I installed it, the car appears to be an inch or so higher in the rear than it was before I installed it. Did I put it on wrong, or is this normal?
Re: car looks "lifted" after rear swaybar install (743)
did you tighten the bolts with the wheels firmly planted on the ground?
i think you should have..
have you moved the car since you put it on?
If you haven't, release the parking brake
Or just go drive it around the block a few times.
If your car got higher, then something is wrong. That is not normal at all.
Re: car looks "lifted" after rear swaybar install (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">have you moved the car since you put it on?
If your car got higher, then something is wrong. That is not normal at all.</TD></TR></TABLE>
I didnt think so. I drove it awhile, and it didnt get lower. I'll have to recheck the way its installed in the morning.
it must be binding somewhere then. When I put my 22mm on, my car was the same.
