2000 Honda Civic sedan - interior fitting
Old 11-11-2012, 08:30 PM
TonariNoTotoro's Avatar
Default 2000 Honda Civic sedan - interior fitting
I was wondering what rear seats would fit in a 2000 Honda Civic sedan.
I'm currently looking at TSX interior and was wondering if the rear seats from a 2004 TSX would fit or not.
If not, what rear seats would work that have an arm rest?
Any help is appreciated!
Old 11-11-2012, 08:42 PM
CO671's Avatar
Default Re: 2000 Honda Civic sedan - interior fitting
96-00 Civic
-Rear-(Sedan)
•92-95 Civic Sedan
•94-01 Integra Sedan
-Front-
•92-95 Civic w/EK rails
•94-01 Integra w/EK rails
•92-97 Del Sol w/EK rails
•97-01 Prelude w/EK rails
•97-02 Accord Coupe w/EK rails
•01-03 CL w/EK rails*Requires 12v for heat feature
Here's a helpful thread
http://www.utahhondas.net/index.php?topic=35678.0
Be a pioneer and experiment to see if TSX rear seats can fit.
Personally I haven't seen (or read online) anybody try fitting in 97-01 CRV Seats into their 96-00 Civic's because the Civic+CRV chassis are so similar I went ahead and did it successfully.
Old 11-11-2012, 09:12 PM
Thank you for the helpful post!
I might try the rear seats idea since the only thing I'd lose is the time in trying to fit them.
Old 11-11-2012, 09:24 PM
I noticed that you said the rear view mirror in your Civic sags down normally. How did you fix this with tape exactly?
Old 11-11-2012, 10:22 PM
CO671's Avatar
Oh where'd you read that? I forgot where I put that lol. I just stuffed a crapload of electrical tape. First I got some paper / receipts or trash I had, rolled it to a cigar size and wrapped it in electrical tape, tucked it where the ball joint of the mirror is so that it acts like a sort of spacer... and stays up especially when my sub is lightly hitting. Very ghetto, and messy but because I have a tint strip on my windshield nobody sees it anyways. I wouldn't recommend it...
Old 11-11-2012, 10:39 PM
I read that on your link in your signature about your '99 Civic.
Ah ok. I have the problem with my rear view mirror sagging. I'm thinking of just going to a junk yard and buying a new rear view mirror.
Old 11-11-2012, 10:42 PM
CO671's Avatar
Well I think this thread can help you
http://www.azht.net/forum/showthread.php?t=126796
Old 11-11-2012, 11:07 PM
HOLY! You are awesome!
Man, you must have an awesome library of useful links!
Old 11-11-2012, 11:14 PM
Do you have any other (random) Civic sedan links that might be useful/helpful for me?
Old 11-11-2012, 11:42 PM
Caddiman's Avatar
I have type R rear seats for sale if ur intrested. check my sig
Old 11-12-2012, 12:03 AM
CO671's Avatar
Yes, lol hundreds bookmarked, here are the ones I found most useful:
(You see some slammed/hellaflush threads I posted, don't lower your car that low though!)
Showoff threads:
** The offical 96-00 civic 4dr thread ** PART 2
SHARE YOUR STANCE - The guide to achieving that ideal setup...
♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
SLAMMED... Suspension Setups.
<<<(**DO NOT POST COMMENTS**)>> Post The Nicest 6th Gen. U Ever Seen
Post Your Sedan READ POST 1 BEFORE POSTING!
Pic request: 96-00 Civic, interior upgrades
Post your rear window visor!
Post your Gauge Cluster swaps!
Post your engine bay
Official SOHC wire tuck thread
What's the most comfortable seat?
Post Your Interior!!! THREAD
EK+EM Owners: Post your OEM seats
Pics of 99-00 Civic Si wheels
Builds:
My favorite K20 powered + Domani conversion Sedan:
SMALL TOWN WINNIPEG? another bys k24 powered 4 dr. honda domani... G106
dancivic(96) civic sedan k24 rebuilt
Info/DIY Compilations:
6th Generation Civic | Info for you and your car
Honda/Acura Main FAQ Page
** Post your DIY's for quick referrence! **
DIY My Honda
Honda Recommended Lubricant list
Interior:
DIY: 96-00 Steering wheel install w/o SRS light and working horn
HOW TO: DIY Custom Interior Project - **NO56K**"
DIY S2000 Cluster in EK/EJ including Bezel
94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
DIY Integra GSR Shifter install into Civic
Acura Integra Short Shifter Install DIY
Honda Civic Short Shifter Install DIY
1999 Honda Civic Sedan bulb size guide
Resource: What OEM steering wheel fits my car?
Please contribute to this "FAQ for Integra rear seat into Civic"
integra seats into ek
Question: 01-05 cluster into 96-00 retrofit
How To Fix A Window That Fell Out Of Its Track
DIY map & trunk light intall for EKs
DIY - 92-96 Prelude seat install in EK [Archive Please]
Exterior
HT - Autobody Repair
How to Aim Your 1992 - 2000 Headlights
DIY 6th gen Civic CTR Headlights: The Difinitive Guide
How-To Install Honda Access Sedan Window Visors ok EK
Honda Domani/Acura 1.6 EL front end conversion
Suspension:
DIY: Budget Swaybar install 96-00 Civic
How to: Progress 22mm Rear Swaybar Install
Do It Yourself Spring Install - Detailed Info & Pics
G3 Coilover/Shocks/Springs Instal
00 Civic - Questions on front/rear sway bars, subframe brace, and strut tower bar
What type of Lug Nuts for Civic Si Rims ???
CLICK HERE all of you curious about suspension setups and their costs/reliability.
Engine:
DIY Wrinkle paint in any color
Valve Cover Painting
DIY Paint your own valve cover
DIY Making an old rusty heatshield look new again
DIY: strip your valve cover and repaint (56K probably not)
paint your valve cover w/ VHT wrinkle red
Rocker arms torque specs / camshaft bolt specs
[URL="http://www.d-series.org/forums/diy-forum/108448-diy-wire-tuck.html"]DIY Wire-Tuck[/URL
RANT: "EK" Coupe and Sedan Exhausts Are the SAME!
How to Wire Tuck
Mechanical o2 Sensor simulator with PICS
$5 o2 cheater/non fouler how-to
FAQ: Axle Replacement Tutorial With PICS!
Replacing your distributor cap and rotor (GEN3)
D-Series Exhaust Manifold Comparison
DIY: How to set your timing during timing belt change/head gasket replacement.
Looking at brake upgrades? Look no further than here.
[URL="http://www.hondahookup.com/info/engine_swap_faq.php"]Complete 92-00 Civic Owners Engine Swapping Guide[/URL
D16Y7/Y8 MINI-ME WRITE UP (56k, maybe not)
D.I.Y. Mini-me Swap (d16y8)
[FAQ] D Series Torque Specs for everyone
Old 11-12-2012, 07:02 PM
Holy! You are amazing!
Thank you SO much!
Old 11-12-2012, 07:13 PM
CO671's Avatar
Ah, here's minor mods that made a difference
Other than a tune-up, oil + filter, spark plug + wire + rotor + cap, fuel filter, brake pads, brake fluid change, radiator flush + coolant change. And grab some Wd-40 to wipe down the engine bay.
$10 Integra shifter, will need to be dremeled or cut + ~$30-$50 weighted **** (PWJDM Brass Knucle 530gm) + $5 DOT 3 Brake fluid + $10 Honda OEM Manual transmission fluid. Maybe even an energy suspension shifter bushing kit too ~$10
Total: ~$65-$85
If your Civic is manual, do the Integra short shifter mod, and grab a heavy shift ****! Maybe service your clutch fluid and refill your transmission oil too, and you will feel so much more comfortable.
$5-$10 for 48-led panel + $5 for a pack of bulbs (194 168 2825 T10) + $5 (31mm 3021 3022 3175 6428 6430 30922 DE3425) For lighting, the integra map-light with white LED bulbs I grabbed from Amazon, and the dome light a 48-led panel. the 3022 bulb for license plate trunk lighting. Amazing difference.
Total: ~$15 - $30
$20 240mm Convex broadway view mirror, another great little modification (not a ricey pain in the *** 5-panel mirror, this is fitting and functional and cheap too) Also a universal side-mirror tape-on blind spot mirror is great. ~$10
~$15 - $30
Old 11-13-2012, 10:20 PM
RA100923's Avatar
Really? Were the CRV seats a direct swap I into an EK sedan?
Do you have pics of it? You've got me interested!
Old 11-13-2012, 10:41 PM
CO671's Avatar
Only fronts are direct bolt in (which isnt worth buying unless you can get them free like I did)
i looked at the rears and it didnt seem right, the lock locations are different and the crv rears sit on high brackets.
Old 11-14-2012, 08:16 AM
RA100923's Avatar
Ok so the CRV rears don't fit properly in an EK sedan.
I recently swapped in the GSR Leather seats into my sedan, and I'm trying to find rear seats now to match. It's hard to find rear/leather seats from an Integra sedan, so I've been considering other options.
Agent_EM1
30
12-02-2017 11:40 AM
ehhvisej8
07-21-2015 02:26 PM
loadedburrito99
02-11-2013 05:44 AM
J-redEK4
08-03-2006 04:28 PM
Quick Reply: 2000 Honda Civic sedan - interior fitting
